show bfd session counters vr all
show bfd session {ipv4 | ipv6} {ipaddress} counters {vr [vrname | all]}
Syntax Description
ipv4
Displays all IPv4 sessions.
ipv6
Displays all IPv6 sessions.
ipaddress
Displays sessions in specified VR.
Default
Displays all IPv4 sessions counters by default if IPv4 or IPv6 is not specified.
Usage Guidelines
Use this command to display BFD session counters.
To clear the counters, use the clear counters bfd command.
The following command displays the session counters:
# show bfd session counters vr all
Following is sample output from this command:
Neighbor : 10.10.10.1     Interface : vlan10Vr-Name :   bfd_vr10
Valid Rx Pkt         : 87
Total Tx Pkt         : 87
Auth Type Fails      : 0
Authentication Fails : 0
Discarded Pkt        : 0
This command was first available in ExtremeXOS 12.4.
IPv6 version of this command was added in ExtremeXOS 15.3.2.
Platform Availability
